07-22-2020 02:00 AM
Hi~ I purchased CISCO equipment, CISCO WebEX Code Plus (model : TTC7-25) and setting finished.
But I tried to direct call with IP address but it didn't go thru.
The I realized that I have to setup(or active) H.323 protocol
but in the configuration menu in Web interface, H.323 menu is not there.........while product spec. mentioned
H.323 protocol supported.
What should I do for H.323 set-up?
Many Thanks in advance.
Solved! Go to Solution.
07-22-2020 02:04 AM
- Check this document , among other topics you may want to consult , also look for H323 settings :
M.
07-22-2020 02:04 AM
M.
