Cisco ASR 9010 - RSP and LC Card Compatibility
aridy
I have a Cisco ASR 9010 Router, that I would like to upgrade.
For the moment the RSPs that I have are A9K-RSP-4G and the line cards are A9K-4T-L and A9K-2T20GE-L.
I want to to replace the existing RSPs with A9K-RSP880-LT-TR.
My question is if the A9K-RSP880-LT-TR are compatible with my existing Line Cards and if is it possible to find any document that shows compatibility between different RSP Cards and Line Cards, because so far I couldn't find any.
Thanks in advance,
Aridy
 - That's a misunderstanding of mine, indeed, I was only referring to the  Table. If your cards are not listed I presume they will be unsupported with that particular route processor.
 M.
marce1000
 Ref : https://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/datasheet-c78-733763.html
            - If you look at Table 4 , I presume that the mentioned line cards would be supported
 M.
Hi Marce,
Thanks for your reply.
As far as I can understand, i think that they are not compatible, because none of my actual Line Cards is part of that table.
Why do you think they are compatible?
 M.
