CISCO WebEx codec Plus H.323 setting issue
Harry86840
Hi~ I purchased CISCO equipment, CISCO WebEX Code Plus (model : TTC7-25) and setting finished.
But I tried to direct call with IP address but it didn't go thru.
The I realized that I have to setup(or active) H.323 protocol
but in the configuration menu in Web interface, H.323 menu is not there.........while product spec. mentioned
H.323 protocol supported.
What should I do for H.323 set-up?
Many Thanks in advance.
marce1000
 - Check this document , among other topics  you may want to consult , also look for H323 settings :
       https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce94/codec-plus-administrator-guide-ce94.pdf
 M.
marce1000
 M.
