Cisco WLC AP count over SNMP
CSCO11724338
Is it possible to monitore a quantity of AP on Cisco WLC and quantity of wireless clients?
I was found only list of AP names over snmp...
Thanks in advance
CSCO11724338
If someone has become interested, I have found only one way.
I have created a power shell script that collect all AP names (1 line in text document by 1 name) and then use wc -l to calculate number of lines.
This script provide me really value of number of AP's. And then, I use this result in our monitoring system to get the graphs.
Script is on linux server machine.
Hi Andrey,
i was just looking for a similar solution.... Are you willing to share the script with us?
Greetings Ralf
Hi, Ralf
If not late
I use script directly in monitoring system
main ()
VALUE=`snmpwalk -v 2c -c xxxCommunityxxx X.X.X.X 1.3.6.1.4.1.9.9.513.1.1.1.1.2 | wc -l`
echo "Message: Warning! Number of registed APs decriased."
echo "Data:Count"
echo "Count\t$VALUE"
exit 0
main $*
This is shell. but you can use simple only one line
(from linux)
Christian Maier
For those reading later.
the MIB/OID to read out the number of AP is
1.3.6.1.4.1.9.9.618.1.8.4.0
And the number of clients is
1.3.6.1.4.1.9.9.618.1.8.12.0
Hope this helps someone.
