Cisco Work (LMS 2.6) Device Configuration
lalit
Can anyone tell me where is the default location of device configuration ( Running conf ) saved in Cisco Work (LMS 2.6) Server.
Thanks & Regds,
Lalit
Michel Hegeraat
Level 7
Level 7
if you enable the so called shadow directory feature under:  Admin -> Config Mgmt -> Archive Mgmt -> Archive Settings
then the defaut location is \CSCOpx\files\rme\dcma
Cheers,
Michel
