07-21-2008 04:16 AM
Hello all,
have anyone had an issue with CW assistant?
After i click on Server Setup under CW assistant, after couple minutes i'm getting an error message saying: Server discovery timed out. Please try again later.
Do you know where can the problem be?
If you need more details, please ask so that i can post it.
cheers
Appreciate your help.
07-21-2008 09:08 AM
This could be a known problem which has sense been fixed. What version of LMS?
07-21-2008 11:50 AM
Hey,
LMS i'm using is version 3.0.
Symptoms i have are very similar to:
This discusion has not been finished, so i was not able to resolve my problem.
Thank's a lot Clarke.
07-21-2008 12:15 PM
Go ahead and download the 3.0.1 update. A lot of CWA bugs have been fixed there:
07-22-2008 04:01 AM
thx for the update.
All updated now, but the behaviour is still the same.
After I click on CWA->Workflows->Server Setup i have to wait for about 5 mins and then the error message appears.
Do you know what is CWA checking during the discovery process? Is is checking any credentials, that could possibly be wrong?
If yes, where can i set them up?
Many thanks.
07-22-2008 07:45 AM
CWA uses the System Identity User to authenticate with LMS. Make sure this user is properly defined under Common Services > Server > Security > System Identity Setup. Also, check to make sure all of the CWA daemons are running:
OpsxmlDbEngine
OpsXMLRuntime
ProcSysBus
There may also be some information in the CWA.log.
07-22-2008 10:34 PM
07-23-2008 09:15 AM
What is the hostname of this server?
07-23-2008 09:19 AM
Also, check your System Identity User password for special characters (e.g. '&', '^', '%', etc.). Make sure the password only contains numbers and letters.
07-23-2008 11:44 AM
The hostname is LMS and the password doesn't contain any special characters.
Can there be a problem with the hostname?
cheers.
07-23-2008 12:00 PM
Not unless the hostname changed after installing LMS. That does not appear to be the case. You can enable CWA debugging under CWA > Admin > Log Level Settings. Also check the Enable Engine Logging box. Reproduce the error, then post the new CWA.log and the logs under NMSROOT/objects/wfengine/Program/TFTP/Backup/DeviceTrace/CScript
