05-13-2005 08:32 AM
I have installed CiscoWorks RMS and have been busy adding devices and getting it all tunned up. I have 7 devices in there, CiscoView is working, I get information on my devices using various functionality but the Campus manager doesn't discover anything! I was wondering if someone can shed a light on this.
Common Services Ver 2.2
Campus Manager ver 3.3 with Java Run Time 1.3.1
CiscoView ver 5.5
Device fault Manager 1.2
Resource Manager Essentials ver 3.5
Masood
05-13-2005 12:25 PM
YOu have to add a seed device (or multiple seed devices)
Go to server config > discovery settings > add your devices here... If you have cdp enabled on all your devices and they can see each other (i.e they are not separated by a WAN/LAN that is managed by a third party like a telco), then you need to add only one device in the seed file and it should find the rest.
Add a switch preferably
05-13-2005 01:20 PM
Thanks very much.
Masood
