cisco works daemon manager could not be start
ahmedhammouche
hi,
i have a problem in cisco works,daemon manager could not be started,the error message is attached below:
c:\net start crmdmgtd
the cisco works daemon manager service is starting.
the cisco works daemon manager service could not be started.
the service did not report an error.
more help is available by typing NET HELPMSG 3534.
C:\pdshow
error: connect to dmgtd process on "127.0.0.1" on port 42340 failed
error: daemon manager startup in progress.please wait
please if anyone know the response help me.
You can plan to update LMS with Service Pack 1 (LMS 3.2.1), where this issue is fixed.
Refer Readme for CiscoWorks LAN Management Solution 3.2 Service Pack 1.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
11 Replies 11
Vinod Arya
Make sure of the following :
> You have admin right on server.
> Start the command prompt with administrator priv's explicitly with a right click option of run as an administrator.
I would say try to run NMSROOT\setup\support\resetcasuser.exe and try once again to start.
-Thanks
-I have admin right on server
-when i run the command NMSROOT\setup\support\resetcasuser.exe   it display:
user casuser is reset successfully
plese restart the daemon manager for the changes to take effect
but the same problem
the cisco worksDaemon manager service on local computer started an then stopped.some services stop automatically if they are not in use by other services or programs.
Can you try to make casuser a part of administrators group and than try.
-Thanks
casuser is a part of administrators group
What is the LMS version and windows version? Please check if you have manually assigned the SWAP space or not? There is a known defect if it is set to automatic.
you can check and change it via System properties > advanced > Performance > Settings > Advanced > Vritual Memory.
Please share screenshot as well. If it still throws error, you should see error in NMSROOT\log\syslog.log file, share the error from there as well.
Also, please make sure you have the correct startup parameters :
CiscoWorks ANI database engine: Manual
CiscoWorks Daemon Manager: Automatic
CiscoWorks RME NG database engine: Manual
CiscoWorks Tomcat Servlet Engine: Manual
CiscoWorks Web Server: Manual
CWCS Cmf database engine: Manual
CWCS rsh/rcp service: Automatic
CWCS syslog service: Automatic
CWCS tftp service: Automatic
DFM dfmEpm database engine: Manual
DFM dfmFh database engine: Manual
DFM dfmInv database engine: Manual
If not like this, correct them and reboot server.
-Thanks
-LMS version 3.2  and windows standard server
-i'm manually assigned the swap space:
custom size :-initial size MB 16256
                    -maximum size MB 32768
space available 85445 MB
-I have the correct startup parameters
-error in syslog.log :
-Jan 07 11:45:14 127.0.0.1 dmgtd: WARNING: System SWAP Memory is less than Required Swap Memory, which may affect performance
-Jan 07 11:45:14 127.0.0.1 dmgtd: Required SWAP space is 4096M and System SWAP space is  0M
-Jan 07 11:45:14 127.0.0.1 dmgt[2676]: 2009(W):System Error: The Daemon Manger cannot bind to port:42340 System Error: The Daemon Manger cannot bind to port:42340 %s.  The TCP port:42340 that the Daemon manager expects to use is not available. Call your technical support representative for assistance..  The TCP port:42340 that the Daemon manager expects to use is not available. Call your technical support representative for assistance.
Is the server win 28k?
If you're sure that the port 42340 is not acquired by any other software/process on server, than it may be mostly # CSCtd18854 - Daemon manager expects TCP port 42340 but it is unavailable.
This needs to be patched. Patch is replacing NMSROOT\bin\dmgtd.exe with the correct one. You need to open a TAC case to get the patch.
-Thanks
port 42340 is not acquired by any other software/proces on server.
give me a answer please.
As I said, this is a bug # CSCtd18854. For fix ether open a TAC case to get the patch or upgrade your LMS to LMS 3.2.1.
You can download LMS 3.2.1 from :
http://software.cisco.com/download/release.html?mdfid=282635181&softwareid=280775102&os=Windows&release=3.2.0&relind=AVAILABLE&rellifecycle=&reltype=latest
-Thanks
versions of LMS
-campus manager 5.2.0
-cisco view 6.1.9
-cisco works assistant 1.2.0
-cisco works common services 3.3.0
-device fault manager 3.2.0
-integration utility 1.9.0
-internet work performance monitor 4.2.0
-LMS portal 1.2.0
-Ressource manager essentials 4.3.0
