Blocking foreign countries
mialbert
Level 3
Level 3
We want to block foreign countries by ip blocks.  I am wondering if anybody has blocked foreign countries this way.  I went to
http://www.find-ip-address.org/ip-country/ and noticed that china alone has 60 pages of ip blocks.  I would be doing this in both isr's and asa's.  Has anyone done such a thing with these.
6 Replies 6
Leo Laohoo
You're not the first I've seen to ask this question in the last three months.  Try this:
https://www.countryipblocks.net/country_selection.php
Marvin Rhoads
In addition to the method Leo suggests, you can also find this built in as a feature in most IPS's. They use a geolocation database lookup as part of the subscription service to keep the listing up to date. Such a feature adds to the value proposition of installing an IPS (if you haven't already).
Happy New Year Marvin.
Out of curiousity, do you think ISPs can do a country block for a client like, for example, you?
Happy New Year to you too, Leo.
I was referring to an Intrusion Prevention System (IPS) not an Internet Service Provider (ISP). I don't think Cisco's exposes this information directly but HP does with the TippingPoint products. Both vendors use the concept of reputation - Cisco via the Global Correlation database and HP with the Reputation Digital Vaccine feature. HP's Rep DV specifically includes origin country as a field in the database.
In any case, either of those vendors will advise you to focus more on observed behavior rather than country of origin. The hacker is as likely to be launching attacks from compromised systems thousands of miles from home as they are from their home base country.
Thanks Marvin.
We haven't gone down this road yet but this topic may pop up some time this year.
mialbert
Level 3
Level 3
Leo's method looks interesting but my concern is the amount of extra inbound packet processing that the isr's/asa's will have to do with an acl to block these countries.  The devices i'd be doing this on would mostly be gen2 isr's(1900's), some 1800's and 5510 asa.  Should this be a concern.
