Cisco Works LMS 4.0 doesn´t start
MarioLieb
Hello All
i have big trouble with me LMS 4.0 installation. I did an Upgrade from LMS 3.2 to LMS 4.0. After that the Works was running without any problems. After some days i´d tried to login on the LMS and it told me something like my lincens where corrupt or so. I´d tried to start the CiscoWorks Demon Manger but he didn´t start. OK after some investigation at the i-net i decided to perform a clean installation of the Server an Cisco Works.
So after i do thes i´d perform a restore of my old Data from LMS 3.2. Now i investicated that my ANI Server Falied to start. OK than i tried to restart the Works Demon ... f... and what will happend ?!?!?! The demon doesn´t start. Can someone help me ?!?! Please i will not perform a new istallation again.
C:\Windows\system32>net start crmdmgtd
The CiscoWorks Daemon Manager service is starting.
The CiscoWorks Daemon Manager service could not be started.
The service did not report an error.
More help is available by typing NET HELPMSG 3534.
Mario
Hi i have an update for this issues ... After i´d tried to start all Works- Services be hand ... all Services will start execpt the deamon ... When i loged in i get messages "License Server/Deamon Manager is down. Please  check license.log for more information."
Thats the same situtaion befor the new installation.
Hi Mario,
KindlyReinitialize the ANI Database to fix the issue..
NMSROOT\bin\perl.exe NMSROOT\bin\dbRestoreOrig.pl dsn=ani dmprefix=ANI
I hope this will fix the issue..
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
16 Replies 16
AFROJ AHMAD
Hi Mario,
Try the below steps:
First of all add the Casusers in the Administrators Group  ( or you can say Casusers should be a memeber of Administrator group)
--Now Execute the below command:
NMSROOT\CSCOpx\setup\support>resetCasuser.exe
Now try to start the daemon Manager
Afroj
Hi Afroj
ok first is ok the Demon is now running thanks for that. but now i have the problem that the ANIServer does not start See Screenshot.
Any idea
Mario
Kindly send me the below 2 files:
ANIServer.properties
ANIServer.properties.ORIG
Afroj
for sure ...
Mario
Thanks for the files. what is the NMSROOT ? ( i mean the directory where the cisco works is Installed )
like :c:\program files\CSCOpx...
Also try this :
pdterm ANIServer
pdexec ANIServer
now check the ANIServer status: pdshow ANIServer
Afroj
Hi Afroj
the NMSRoot is D:\CiscoWorks\CSCOpx
and here the outbut of ANIServer status
C:\Windows\system32>pdshow ANIServer
        Process= ANIServer
        State  = Failed to run
        Pid    = 0
        RC     = -2
        Signo  = 1073741822
        Start  = N/A
        Stop   = 8/19/2011 3:19:17 PM
        Core   = Not applicable
        Info   = Application failed or was registered incorrectly. C:\Windows\system32>pdshow ANIServer
        Process= ANIServer
        Pid    = 0
        RC     = -2
        Signo  = 1073741822
        Start  = N/A
        Info   = Application failed or was registered incorrectly.´
Mario
Hi Mario,
Please replace the ANIServer.properties file with the attached file.
--Make sure you backup the Original file
--Also make sure we have all the required premission on the new file
then try to start the ANIServer..
Afroj
Hi Afroj
first thanks for the file ... but
After i replaced the file and checked the permission i´d tried to start the ANIServer.
It starts for ca 1 minute with busy flag and than the service stoped wirh the same error. Sorry any idea ?!?!?!
Help please i need Works very often ...
Thank
Mario
C:\Users\liebm-a>pdshow ANIServer
        Process= ANIServer
        State  = Running with busy flag set
        Pid    = 18092
        RC     = 0
        Signo  = 0
        Start  = 8/22/2011 7:10:38 AM
        Stop   = Not applicable
        Info   = ANIServer started.
        Process= ANIServer
        Pid    = 0
        RC     = -2
        Signo  = 1073741822
        Start  = N/A
        Stop   = 8/22/2011 7:11:06 AM
Hi Mario,
Afroj
Hi Afroj
f.... this also doesn´t work ... see outbut
After i´d tried to Restore the DB
D:\CiscoWorks\CSCOpx\bin>perl.exe dbRestoreOrig.pl dsn=ani dmprefix=ANI
WARNING: Existing contents of ani database will be lost.
Do you want to continue [y/n]?y
WARNING: Could not delete file D:\CISCOW~1\CSCOpx\databases\ani\ani.db
WARNING: Could not delete file D:\CISCOW~1\CSCOpx\databases\ani\ani.log
ERROR: Service - 'ANIDbEngine' is not stopped
ani registration failed
INFO: Company=Cisco Systems;Application=NMTG;Signature=010fa55157edb8e14d818eb4f
e3db41447146f1571g32125eb777a87cbf8b29a954f559d4221b792ff8
INFO: Preparing AUTH cmd
INFO: AUTH Executed
INFO: AUTH cmd finished
INFO: Stopping the Database engine ani
INFO: Database [ani] authenticated successfully.
ani database initialization failed.
Then i´d tried to start the ANIServer
D:\CiscoWorks\CSCOpx\bin>pdshow ANIServer
        Process= ANIServer
        Pid    = 0
        RC     = -2
        Signo  = 1073741822
        Start  = N/A
        Stop   = 8/22/2011 8:42:27 AM
        Info   = Application failed or was registered incorrectly. D:\CiscoWorks\CSCOpx\bin>pdshow ANIServer
        Process= ANIServer
        Pid    = 0
        RC     = -2
        Signo  = 1073741822
        Start  = N/A
What the hell is happend ?!?!?!?!?
Thanks Mario
Hi Mario,
For some reson Database was not Re-Intialized ..
INFO: AUTH Executed
--Are you logged in as a LOCAL ADMIN ?
--Is your server under Domain ?
try to Re-Init again with LOCAL ADMIN and see how it works !!!
Afroj
Hi Afroj
the Server is in a domain. The server is running under win2008r2 SP1 standard.
I´d tried to re-initialized the database with a local admin and the same error accour.
Then i´d tried to move the databasefile y hand and then i get an error message that told me the file is in use by another process ... See screenshot
thx
mario
Hi Mario,
As you are running   win2008r2 SP1 standard. Have you applied this Patch ? Please check the below link :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/install/guide/instl.html#wp1616783
Afroj
Hi Afroj
yes i did ....
I got a mail which says that Martin Ermel did response this post but i cann´t see the post. Here the answers for his questions. Maybe it will help.
Re: Cisco Works LMS 4.0 doesn´t start
created by
MARTIN ERMEL
in
Network Management
View the full discussion
before doing anything with database files (e.g. re-init, copy) you have to stop LMS;
re-init of a database is more than just copying a file, so be careful what you  are doing...
When you did the new installation of LMS,
    - was it on the same server?
    - if yes, how did you do the uninstallation
    - have you changed NMSROOT from LMS 3.2 to LMS 4.0 ?
    - please provide the ani.log
- i stoped the LMS with net stop crmdmgtd
- no i´d install LMS 4.0 on a new Server Windows 2008 Standart 64 BIT (Old Server LMS 3.2 Windows 2003 Standart Server 32BIT)
- no i don´t change the NMSROOT
