Hi Shoaib,
where did you get this Error msg"You are using unsupported Version"
It must be when you are trying to login to the GUI ?
If yes check the if you are using the supported Web Browser. below is the supported list :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/install/guide/prereq.html#wp1144164
For you other issue:
--check your device discovery settings
--check the SNMP Community defined in the discovery settings ..
--which protocol you are using for device discovery CDP ,routing protocols , etc... try using onlt CDP and PingSweep.
I hope this will help
Afroj
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
