Cisco works - problem adding device.
tin.ngo
Level 2
Level 2
We have Cisco Works RME 3.5 on Solaris and the problem is as follow:
We have a Pix Firewall which had been working fine under Cisco Works. We changed the IP address of the Firewall and need to update it on Cisco Works.
I deleted the device from CW and add it again using the Import method as I always do. The device went in but when I checked the status, it reported no data.
I can still add other new devices and everything is OK except for just this one. Please advice or send URL on how to troubleshoot this problem.
k.poplitz
Level 7
Level 7
Hope you would have configured the PIX to allow the SNMP queries from Ciscoworks server, or else just have this command in the PIX
snmp-server host x.x.x.x (where x.x.x.x is the ip of the CW server)
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_tech_note09186a0080107e08.shtml
The above link will help you resolve issue with troubleshooting.
