I have a problem that I need some help with. I have a copy of cisco works loaded on two systems.
I'm trying to manage a bunch of Cat2950s. Problem is that on one when you bring up one of the 2950s in the cisco view it will allow you to monitor and configure the switch. The other system when you bring up the same 2950, it does not give you the chance to manage it. It lets you monitor it, or try to manage it as a stacked/clustered system.
Any suggestions
Ken Taylor
