Hi i am using Cisco WS-C3560G-48TS
SW Version: 12.2(44)SE6
System image file is "flash:c3560-advipservicesk9-mz.122-44.SE6.bin"
Router bgp limitation is <1-65535> Autonomous system number
but i need to set the bgp 134084 when i try to set 134084 its shows error "% Unrecognized command"
If i update the System image file will it fix my problem ?
or how can i use bgp 134084 at this configuration ?
Thank you advance :)
