ciscoMARS
followurself
Level 5
Level 5
Has anyone evaluated CISCO MARS with checkpoint firewall. The doc says it supports checkpoint firewall but would appreciate if someone has used it and to what extent does it support
chrisd
Community Member
Hi, what do you want to know?
Checkpoint will basically send all its event logs over to the MARS box. You will see incidents created, for Rules that Fire, like config changes, SmartDefence Blocks, Worms, Peer to Peer etc
