Ciscoprime 3.1 syslog messages
Massimoriboli
Hi all,
i have a simple question, it's possible to send a particular syslog message via email using Ciscoprime ?
I want to send the port flapping syslog message to an email recipient.
Best Regards
Massimo Riboli
Marvin Rhoads
I believe the option Mark is citing only applies to syslog messages generated by Prime Infrastructure.
The ability to take action (Email, raise alert, etc.) based on a syslog message RECEIVED by Prime Infrastructure is something we've been asking the business unit about for some time now.
Last I heard it was on the roadmap for a future release.
Sad because this basic capability was in Cisco's own LMS and is in competitive products like SolarWinds NPM (and has been for many years).
Mark Malone
you can set the logging facility level which will alow certain messages depending n which level you pick , but you cant say just say send me BGP logs
it has user -local1 -local7 available to pick from
here's the output for PI 3.1
SysLog Settings
Enable SysLog  Enable
SysLog Host
SysLog Facility
Marvin Rhoads
Thanks a lot.
Best Regards
Massimo Riboli
