Ciscoworks 2.5 install problems (RME permissions)
david.bradley
I'm having issues with Ciscoworks 2.5, but the problems seem to be limited to RME.
If I log into Ciscoworks I have access to all areas except RME, if I launch RME I see the 'you may not have permissions' message and I unable to access anything. I'm a sysadmin etc... etc.. all the rights.
I have tried removing the application and reinstalling it to not avail, the uninstall/installs do not report any errors, I have tried applying the December 2005 updating taking the install to 2.5.1 this does not help.
Does anyone know why this would be happening? and possibly have a solution?
This is the Solaris version if it makes any difference.
Dave
David Stanford
Have you integrated LMS with ACS?
