Ciscoworks 3.1 Operative System Compability
elix_aaron
Hi Everybody.
Im going to install a Ciscoworks 3.1. I found that it only works on win 2003 server english or japanesse version. My question is..
Can I install ciscoworks on any of Win 2003 server spanish version... or Win 2008 server english version....??
Joel Monge
Spanish OS are not supported.  LMS 3.1 is not supported on any 2008 version.  However, you might want to install LMS 3.2 which is supported on Windows 2008 Standard or Enterprise with SP1 and SP2.  You can check the 3.2 prerequisites here.
Thank you very much, I really appreciate your help.
