In Ciscoworks 3.1 what is the best method to make a config change on your switches? I want to add some usernames to my access switches. Would i do this thru RME?? Any help is appreciated.
You would use RME NetConfig and select one of the predfined task such as username or enable if that is what your looking for or enter your own "adhoc" cli commands .
