Ciscoworks 3.2 Notification Failure
saifmohdali
Community Member
I got LMS 3.2 installed with DFM 3.2.0..
I have problem about the email notification.
I have configure the SMTP server and test by sending a report to my email. and it is works. so as i assume that, my email setting was good.
Thus, i configured the notification and test by lowing the threshold to create alert intends to make sure notification will be sent by email.
However, only DFM alert was occured but no email was received.
I am beginner in ciscoworks. I hope you guys can help by give me clues to solve this problems.
AFROJ AHMAD
HI Saif,
Try the below steps and let me know how it works :
* stop the Daemon Manager ( net stop crmdmgtd)
* Took the backup of existing nos.jar from
NMSROOT\MDC\tomcat\webapps\triveni\WEB-INF\lib and replace with the one that is attached in the Patch .
* Took the backup of existing five class files( check the names from the Patch ) from
NMSROOT\MDC\tomcat\webapps\triveni\WEB-INF\classes\com\cisco\nm\trx\nos\server
and replaced new files
* Start the Daemons (net start crmdmgtd )
Note : You can download the Patch from cisco.com (CSCtg43956)
Thanks--
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
HI Saif,
Thanks--
Afroj
Thank You Afroj..
your patch works!!!
i follow step by step and just in sec, i received notifications..
thanks bro...
