11-17-2011 02:53 PM
I have fresh installed the LMS 3.2.1 without any errors. Then I am adding device in CS, give it correct credentials. Its appears in RME automatically, but it always remain in Pending devices in RME.
I have run a job in RME to check the devices credentials and it's appearing that credentials for snmp are wrong but ssh/ telnet appears as "did not try". Although I have added the correct credentials in CS for device, but it appearing as wrong in RME.
Also when I add device in CS, it's not automatically picking it's device type, until in CS I define its device type manually.
Please advise a solution for thiss problem.
11-18-2011 12:29 AM
This usually indicates that SNMP contact to the devices fails
I use the CLI tools like \CSCOpx\objects\jt\bin\snmpwalk.exe to check this.
Cheers,
Michel
11-22-2011 07:37 PM
