Ciscoworks and IE7
rodman1231
Can CiscoWorks work with IE7? If so, has anybody found any serious bugs?
5 Replies 5
Joe Clarke
CiscoWorks is not currently supported with IE 7, so you may run into problems. We are planning for support in the upcoming LMS 3.0 release in late spring of next year.
w.kuhn
Tried it... works a treat with the tabs...Must admit that it's quite a pain with IE6 opening multiple windows everytime you access a link in LMS2.5.1. See that Mozilla is now supported in 2.6
The only thing not working is in Campus Manager> topology Services and any component requiring ANI server to load data... it just stays blank.
How did you get IE7 to work with LMS 2.5.1? Thanks.
As I said, not all components work with IE7. The only thing I discovered not working is when ANI server loads data which renders some packages in Campus Manager not working. RME, DFM, IPM, Common Services all worked fine. Same happens with Firefox.
Thanks for the info on this topic. I think, for now anyway, that I'm going to stick with IE6. When the issues are worked out I will switch at that time.
