CiscoWorks and Parameterized templates ERROR - Help Joseph:-)
lap
Level 2
Level 2
I am using CiscoWorks RME 4.3.1 I am trying to use Parameterized templates as explained in this document:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.3/user/guide/netcfg.html
Here is my XML file located in the right place: NMSROOT\files\rme\netconfig\cmdFileson the CiscoWorks server:
<DEVICE NAME = 10.60.131.1>
<CMDPARAM NAME = ConfigFile>
<value>TST4CUPE10-Confg-PV.txt</value>
</CMDPARAM>
</DEVICE>
Then in RME I creat a user-defined task  as the one you can see there:
Then I create a new job on a device with the parameterized file:
Actually if I put a tick in the Check Syntax I got the following error message:
I don't understand as the value is configured in the xml file as you can see above!
When the job is done I get a status: successful:
But the problem is that nothing has changed on the device cause of the following error:
configure replace bootflash:$ConfigFile force
Error: Could not open file bootflash:$ConfigFile for reading
Here is the result on the screen:
Does anyone knows what could cause this error?
Best regards,
Laurent
You have to specify the device's display name in the param file.  Try this:
bootflash:TST4CUPE10-Confg-PV.txt
11 Replies 11
lap
Level 2
Level 2
Hi Folks,
Any ideas?
Best Regards,
Laurent
Joe Clarke
First, do not tick the Check Syntax box unless you have your own external syntax checker.  Next, change the value of the variable from TST4CUPE10-Confg-PV.txt to bootflash:TST4CUPE10-Confg-PV.txt, then use the command:
configure replace $ConfigFile force
Hi Joseph,
Thank you very much for replying!
I have made the changes you told me but I still get the samme error:
Error: Could not open file  $ConfigFile for reading
I am getting mad! I have tried so many things!
Laurent
Can you confirm you're properly selecting the parameter file.  To select it, you need to double-click on the file in the selector dialog.  I see no other problems with your setup.
Hi Joseph,
Here you are:
Here is the parameter file on the CiscoWorks server:
It is a .txt file, should it be a .xml instead?
Laurent
Hi Joseph,
Just to let you know. I have tried with a .XML instead and I get the same problem!!!!
I don't understand what could be wrong! It should be straight forward!!!
Laurent
Change the DEVICE part of the file to GLOBAL:
See if that works.  If it does, it could point to a problem with device mapping.  How does your target device appear in the device selector?
Hi Joseph,
With Global is working perfectly actually!
Regarding the device selector here is a print screen:
What do you think the problem is?
Laurent
Hi Joseph,
I have tried to replace the IP by the name has you said and unfortunaletly I get the following error:
Really strange,
Laurent
Hi Joe,
I have a good news. It is working now after I changed the IP to the hostname as you suggested.
But it was not working even with the hostname because I had a “<” too much.
bootflash:TST4CUPE10-Confg-PV.txt<
So now the file look like that:
Thank you so much for your help! That is fantastic
Best Regards,
Laurent
