Patch for Device Fault Manger
Ivan Denezhkin
Hi!
I tried to install the latest patch dfm3.2-win-CSCtj572681.0.tar for Device Fault Manager. During installation I recieved this message
C:\temp\CSCtj57268-1.0>C:\PROGRA~1\CSCOpx\bin\perl  CSCtj57268-1.0.pl
The patch is getting installed.....
3.2.0
This Point Patch is not intended for this version of  dfm.
If you go ahead and Install this patch some functionality  of
dfm might malfunction.Please confirm with TAC before applying the  patch.
Do you wish to continue (Y/N) [Y] :
Why does it appear? How can I solve this?
Thanks for the patience.
Kindly go ahead and apply the patch. I try to apply the patch on my server and getting the same error. After applying the patch DFM is working fine without any issue. So, this issue seems to be cosmetic only.
Gaganjeet
7 Replies 7
Gaganjeet Chug
Level 4
Level 4
Kindly post the screenshot of Common Services > Software Centre > Software Update.
Thanks ,
Gaganjeet
Here you are.
Thanks for the screeshot. Kindly send me the followings :-
1>  CSCOpx/setup/patch
2>  perl file from the bug i.e CSCtj57268-1.0.pl
Gaganjeet
Kindly disregard the above reply and instead of that send me the followings :-
1> CSCOpx\setup\dfm.info
Gaganjeet
Content of CSCOpx\setup\dfm.info
CATEGORY=Application
VERSION=3.2
PATCHVER=0
VERSTR=automatic builds
CMFSERVICES=System
DEPENDS=mdcbase
REC_RAM_DevicesLimit_100=256
REC_RAM_DevicesLimit_300=256
REC_RAM_DevicesLimit_1500=512
REC_RAM_DevicesLimit_5000=1024
REC_RAM_DevicesLimit_Default=512
REC_SWAP=4096
REC_DISK=2
PROD_INFO=dfm
PRODNAME=Device Fault Manager
VISIBLE=Y
UNINSTALLABLE=Y
DBPASS_REQD=Y
PRODUCT_INFO_LIC=DFM 3.0
JRUN_CLASSPATH=/MDC/tomcat/webapps/triveni/WEB-INF/lib/log4j.jar:/MDC/tomcat/webapps/triveni/WEB-INF/classes
ITM_TYPE=ENTERPRISE
SSL_COMPLIANT=YES
TAGS=kls dfmdb epm nos tis ptm pm adapters dfmad dfmsd dfmgr dfmnm  dfmz cfi fhs afd dps vgm
REC_CPU=1600
ALIAS=dfm
BUILD_ID=NT_DFM3_2_20090521_2305_daily
BUILD_NUMBER=236
BUILD_TSTAMP=1242927308
IS55_SCRIPT=dfm_a
INSTDATE=1-20-2011 04:51:43
CHOICE=Y
DEFAULT=Y
PRODUCT_NAME=CiscoWorks
SHORT_PRODUCT_NAME=CiscoWorks
REGISTRY_ROOT=SOFTWARE\Cisco\Resource  Manager\CurrentVersion
VENDOR=Cisco Systems
LOG_FILE_NAME=Ciscoworks_install_20110120_045137.log
REBOOT=OFF
RUN_DMGR=ON
ABORT=OFF
IS55_SCRIPT_UNINSTALL=dfm_a
Thanks for uploading both the files. Though both the files look good but I will try this in my lab first and let you know the results, so that it willn't effect any fuctionality in your CiscoWorks.
Gaganjeet
Gaganjeet
