CiscoWorks configuration changes reports required
raza555
Level 3
Level 3
HI,
I am using CiscoWorks LMS 3.2.1. Please advise that how I can generate a report that shows that configurations changes made by the someone similar to below “sh archive log config all”
I can generate a report from RME->Report->Report Generator->Syslog-> then tried all types of option for report generation. But I get report just saying that Devices interface has ben up/down. Primary vlan changes; but these all are not usefull for me..
I need a report that who has login to router/switch via telnet/ssh/snmp, make any changes, or been to conf t similar to as below. Please advise if its possible to create these type of reports.
Switch-1#sh archive log config all
idx   sess           user@line     Logged command
   1     1       user1@vty0     | logging enable
   2     1       user1@vty0     | logging size 500
   3     1       user1@vty0     |  hidekeys
   4     1       user1@vty0     | notify syslog
   5     2       user1@vty0     |interface GigabitEthernet1/0/2
   6     2       user1@vty0     | description testing-2
   7     3       user1@vty0     |interface GigabitEthernet1/0/3
   8     3       user1@vty0     | description testing3
AFROJ AHMAD
Hi Rizwan,
check the below threads. It is possible via Chnage Audit .
https://supportforums.cisco.com/thread/2242841
https://supportforums.cisco.com/thread/2241836
also look at the below link:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/user/guide/admin/caudit_swim.html
Hope this will help
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
