CiscoWorks DEE not exporting well-formed XML
mfreeman451
Has anyone else expierenced CW2000 generating bad XML? It's firing out invalid XML tags for the VLAN stuff right now:
ERROR in '':
not well-formed (invalid token) at line 5312, column 9, byte 223636:
</Spanning-tree>
<Vlan>
<Vlan_99,210-212,500>
<command>vlan 99,210-212,500</command>
</Vlan_99,210-212,500>
I'm going to have to write a parser that will change that to <vlan name="Vlan_99,210-212,500"/>
mfreeman451
I've included some code that will help with these issues.. I haven't written a script yet to fix the vlan problems im having, but heres some other stuff..
The first one is a validator, run this through your .xml file to make sure it is well-formed, if its not, nothing will be able to parse it.
#!/usr/local/bin/perl
use XML::Parser;
my $xmlfile = shift @ARGV; # the file to parse
# initialize parser object and parse the string
my $parser = XML::Parser->new( ErrorContext => 2 );
eval { $parser->parsefile( $xmlfile ); };
# report any error that stopped parsing, or announce success
if( $@ ) {
$@ =~ s/at \/.*?$//s; # remove module line number
print STDERR "\nERROR in '$file':\n$@\n";
} else {
print STDERR "$xmlfile is well-formed\n";
I'm not really sure if this 2nd one is going to be useful for anybody. The first time I used DEE, someone sent me all of the data in an .xls spreadsheet, which I then promptly converted to .csv, so it may have been excel mangling the XML data.. not really sure, but maybe it will be useful:
use strict;
#undef $/; # suck in whole file for each read
my($no_desc,$found_desc,$descstring);
my($no_romver,$found_romver,$romstring);
open(F, "$xmlfile") or die("Couldn't open XML file: $!\n");
while() {
chomp;
# strip out quotes
$_ =~ s/""/"/g;
# rip out leading and trailing quotes
$_ =~ s/"
$_ =~ s/>"/>/g;
# remove whitespace garbage bullshit
$_ =~ s/value=\"(.*?)\s+\">/value=\"$1\">/g;
# fix whitespace / newline issues
$_ =~ s/value=\"(.*)\"><\/AD>$/value=\"$1\"><\/AD>/gs;
#$ fix sysobjectid tag
$_ =~ s/(.*?)?\s+/$1/g;
# code to fix the broken ass description tag
if ($_ =~ m/^/) { # match the beginning of the Tag
$found_desc = 1;
$descstring .= $_ if ($found_desc); # match anything inside the tag
if ($_ =~ m/<\/Description>/) { # End of the tag
$descstring =~ s/\n/\s/g; # replace newlines with spaces
$descstring =~ s/"/\s/g; # remove quotes that might be in middle?
# put quotes in front and end of string
$descstring =~ s/(.*)<\/Description>/\"$1\"<\/Description>/;
print "$descstring\n";
# reset our variables..
$no_desc = 1;
$found_desc = 0;
undef $descstring;
next;
next if ($found_desc);
$found_romver = 1;
$romstring .= $_ if ($found_romver); # inside of
# fix the broken romstring..
if ($_ =~ m/^\"><\/AD>/) { # end of
$romstring =~ s/\"\"//g;
$romstring =~ s/value=\"(.*)><\/AD>/value=\"$1\"><\/AD>/;
print "$romstring\n";
$found_romver = 0;
undef $romstring;
next;
next if ($found_romver);
# Fix shit for missing quote on ConfigReg thing
$_ =~ s/AD name=ConfigReg\"/AD name=\"ConfigReg\"/;
print "$_\n";
