02-09-2012 03:41 AM
hi,
i need to know the descripiont about the "event updated" column in the alert and activities window, in this document
i have found 3 on 6 description:
•Environment: Temperature, fan, power supply, voltage information
•System: Hard disk, RAM, processor, memory information
•Interface: Interface, port, card information; IP addresses on the device
but not
Reachability:
Other:
Utilisation.
any help will be appreciated
02-09-2012 05:46 AM
This is old stuff. Not sure what you are after really.
Reachability and Utilization are not displayed in the DDV but are controled under the thresholds for that type of port.
Access, trunk or Interface.
Cheers,
Michel
02-14-2012 06:37 AM
i know , it's an old version, but this is what i have .
thanks for help.
cheers.
03-02-2012 08:59 AM
hi,
i need again your help, i must create a document based to this version for a procedure to change a threshold alarm utilisation on a interface, nor a group, but only in a single interface of the router, but until now i don't have the privilege so i have only the guide but isn't so easy to understand without the program.
can you help me whit a step to step guide?
