CiscoWorks LAN Management Solution
mmtantawi
Level 3
Level 3
I have here 2 Core Switch 4507 and 70 Edge Switchs 3560 Series.
I do not have any Network Managment Software for My Compoany at all.
Now, i did search for CiscoWorks LAN Management Solution, and i found alot of Prices.
i want to Purchase it.
when i did search, on it, i found it with Multiple choices as following :-
A- CiscoWorks LAN Management Solution Large Enterprise Package - ( v. 2.5 ) -
( v. 2.5 ) - product upgrade license - 1 server, unlimited devices - upgrade from CiscoWorks LMS 1.x / RWAN 1.x - UNIX, Win
MFG#: CWLMS-2.5-URUP-K9.
The Price of it is 9,295 $.
2-CiscoWorks LAN Management Solution Enterprise - ( v. 2.5.1 ) - product
( v. 2.5.1 ) - product upgrade license - 1 server, 300 devices - upgrade from Cisco Works LAN Management Solution 2.5 - Win, Solaris
MFG#: CWLMS-DEC05RMR-K9
The Price is 373 $.
Now in My Situation , in order to Purchase this Product for the First time for Number of 50 Devices in Cisco as " Switches & Routers ",
do i have to Purchase the first one with 9,295 $ , or i can go directly with 373,99 $ ?
6 Replies 6
nhabib
Level 11
Level 11
If you do not have a previous version of CiscoWorks LMS, then you will not be able to order the one for 373,99 $
You may want to contact your Cisco re-seller for additional information.
Yes, i do not have it all.
so the Only way to have this Software is to buy one with cost of 9000 $, is that correct ?
its too expesive for me , do you know any other Product that can do the same Function but with cost not more than 500 $ ?
i need something like Cisco-Works , do you have any other Product but with cost not more than 500 $ ?
Try Cisco Network Associate (CNA). It's free.
From Where Can i get , do you know ?
and do you think it will work with the same function as Cisco Works Or Not ??
i did some search on google , but i could not find any thing software related to it .
they are talking about ccna.
do you know from where can i download it ?
