03-04-2010 01:00 AM
Hello everyone,
I work with CW LMS 3.0.1 with the following product versions installed:
Products Installed | |||||
Showing 1-8 of 8 records |
1. | 3.1.1 | 02 Mar 2010, 10:34:04 CET |
2. | 5.0.2 | 02 Mar 2010, 10:34:05 CET |
3. | 6.1.7 | 02 Mar 2010, 10:34:10 CET |
4. | 1.0.1 | 02 Mar 2010, 10:34:10 CET |
5. | 3.0.5 | 02 Mar 2010, 14:55:12 CET |
6. | 4.0.1 | 02 Mar 2010, 10:34:14 CET |
7. | 1.0.1 | 02 Mar 2010, 10:34:17 CET |
8. | 4.1.1 | 02 Mar 2010, 10:34:18 CET |
Many Thanks in advance,
Luca
I verified that RME has a license to support 1500 devices while the devices discovered by RME are about 1600.Solved! Go to Solution.
03-04-2010 11:39 AM
In LMS 3.0.1, you must remove them manually. LMS 3.2 has a feature which can poll devices in DCR, then generate a report for those which are no longer reachable. That will then facilitate removing those devices.
03-04-2010 11:39 AM
