06-09-2011 08:42 AM
I am trying to determine the easiest way to determine which of my devices are running HSRP. Would there be a report for this, or do I need to run a show standby command on all my devices and then go through the results?
help is appreciated.
Solved! Go to Solution.
06-11-2011 09:42 PM
If all you care about is finding all devices running HSRP, do an RME Search Archive for "standby". That will list all matching devices. From there you can export the device list to operate on those devices.
06-11-2011 09:42 PM
06-14-2011 11:39 AM
thank you, I will give it a try.
06-14-2011 01:14 PM
that did it. Very easy too. thanky ou sir
