CiscoWorks LMS 4.0.1 and devices other than Cisco.
andrea.meconi
Level 2
Level 2
Hello.
Can I use some CiscoWorks LMS functions like config management, topology, with devices other than Cisco?
Thanks.
Andrea
Michel Hegeraat
Level 7
Level 7
No, RME, Campus and DFM are still hardcoded to restrict to cisco devices.
HUM and IPSLA are more open.
The functionality from the HUM will allow you to monitor availablilty, interfaces and you can add OID's yourself.
IPSLA can use non cisco devices as a target for their tests.
Cheers,
Michel
Hello Michel.
There is a way to run a script? I need to collect HP VC configuration!
Thanks.
Andrea
Andrea,
It is not going to be a part of the configurations like you have with RME for cisco devices.
But you can launch a script based on a syslog message from the HP device is the device is in the LMS DCR.
Up to you to make the script to get and store the configuration.
Cheers;
Michel
