CiscoWorks LMS 4.0.1 - Interface Availability graph
Ferenc Kuris
Level 2
Level 2
Hello all,
I would have a question about CW LMS Monitoring Interface Availability Graph. When we change a Network Topology (for example I plug out a switch from a daisy chain and plug it in the distribution switch), the Interface Availability shows the original switch port as unavailable. After a big change, we have several interface notification on the diagram with red, but the devices are available - of course, we just changed the port where it is plugged in.
In what menu can I rediscover a devices, and why shows the CW the unused, old interfaces as 'down'?
Thanks in advance,
Ferenc KURIS
tobin_jim
Level 2
Level 2
Hi Ferenc,
Did you ever get a solution to your question. I'm having the same issue after making changes to the devices in our Ciscoworks deployment.
Jim
sorry, no. I tried to set the unused interfaces to unmanaged state, in some cases it solved the problem. But this is not a really solution. I hope somebody has any other idea that helps us.
