11-25-2013 05:50 AM
What’s the difference between LMS 4.2 vs Cisco Prime Infrastucture 2.0. We have both products with little experience and just want to make decision that which ONE product we use.
What product you recommend.
Is it possible to view the topology maps on Cisco Prime Infrastucture 2.0.
Solved! Go to Solution.
11-25-2013 06:22 AM
here is the comparison matrix of the features supported in LMS and PI:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/guide_c07-729089.html
Topology is Not supported yet in Cisco Prime Infrastucture 2.0 , however it is in the future plan.
LMS is mainly for LAN or wired device management of the network..
is a recent member of the Cisco Prime for IT portfolio. It provides planning, configuration, availability, performance monitoring, and troubleshooting of wireless and wired networks.
is the most recent version of Cisco’s most popular network management software. It simplifies the configuration, compliance, monitoring, troubleshooting, and administration of Cisco wired networks.
Thanks-
Afroz
[Do rate the useful post]
11-25-2013 06:22 AM
Thanks-
Afroz
