CiscoWorks LMS2.5 - How do I generate a reprot
victoria.evans
How do I generate a device report that show the chassis information and status of the interfaces (up, down, administratively shut down)for all devices to include the number of ports that are available? Thank you.
Joe Clarke
See this thread:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddf4dcd
While you can get this information via the Detailed Device Report in RME, it sounds like you're trying to determine where you have port capacity in your network. In that case, the Switchport Usage reports in User Tracking will tell you. As was pointed out in the above thread, those reports have been enhanced and extended in LMS 3.0.
