CiscoWorks QPM 3.2 and CiscoWorks LMS 2.5 on same server ?
ssaindon1
We'd like to install CiscoWorks QPM 3.2 on the same server as CiscoWorks LMS 2.5. The documentation says we can do it with LMS 2.2.
Can we extend this statement to include LMS 2.5 or some other restriction would prevent this coexistance ?
Thanks !
Steve Saindon
DGAG
rmushtaq
Level 8
Level 8
No. QPM 3.2 requires Common Services 2.2, whereas LMS 2.5 runs on top of Common Services 3.0
Thanks for your answer. Another question though :
If we wait for the next version of QPM, will it use Common services 3.0 ? In which case, it could be installed on the same server as LMS 2.5 ? And if so, do you have any time frame for the next version of QPM ?
Steve Saindon
DGAG
Not sure when the new version of QPM will be available. Recommendation is to keep both apps separate
We'll keep both apps separate then.
One way to do that according to the server guys here, is to use multiple partitions on a high performance server. They would use EMC's VMWARE to give us two separate environments for CiscoWorks LMS and QPM.
Are there any known issues with the use of CiscoWorks on a virtual machine instead of a basic single-thread server ?
Thank you !
