02-12-2011 02:50 AM
Hi Folks
I M Going to Run cisco works 3.2 in my Enterprise so what is the required config in the router and switch and asa along with a basic config in the CiscoWorks it self?
02-12-2011 03:13 AM
what you need is:
-make sure that the device is reachable from the LMS server
-enable the SNMP protocol on the devices (snmp-server community
-if you need to send the syslogs to the LMS server you can use the logging host
hope this helps.
02-12-2011 08:19 AM
what is needed from the lms side as basic config after setuo to see all ur activew compononts?
