CiscoWorks with Edges
Ibrahim Jamil
Level 6
Level 6
Hi Folks
I M Going to Run cisco works 3.2 in my Enterprise so what is the required config in the router and switch and asa along with a basic config in the CiscoWorks it self?
Fadi Twal
what you need is:
-make sure that the device is reachable from the LMS server
-enable the SNMP protocol on the devices (snmp-server community RO) and if you like also to configure the RW community.
-if you need to send the syslogs to the LMS server you can use the logging host
hope this helps.
what is needed from the lms side as basic config after setuo to see all ur activew compononts?
