CiscoWorks3.2
Why ciscoworks in endhost in usertracking report  doesn't get all interfaces in switch or routers ?
justin.barnhill
Community Member
perhaps you mean switchports and not endhosts? try checking in Reports > Switch Port > Ports
Thanks Justin  but Endhost report give me all details  about switch or router interfaces like(status active or inactive),IP address , Vlan name   so my problem is Endhost report doesn't get  all interfaces in switches or routers
so if you have another way  to get this information please inform me
try Switch port summary report under Campus Manager
Thanks-
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
