class based qos MIB implementation into LMS
akaradum
I need to implement the cisco-class-based-qos MIB into LMS 4.0. Since its an open source MIB, cisco does not offer a download for all the dependencies. The ones offered are fine, but most of the rest I couldn't find. (did a lot of googling, the ones I managed to find fire up errors when I try to implement them to LMS, so I'm guessing they are altered versions.)
Does anyone have those dependencies and provide me some insight on the usage of this MIB?
Thanks a lot in advance
Ant
Martin Ermel
perhaps this can help you:
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&submitClicked=true&mibName=CISCO-CLASS-BASED-QOS-MIB#dependencies
and the hint from this thread, that there are dependencies with RFC1158-MIB which are not listed
https://supportforums.cisco.com/message/671319#671319
there are also sveral places to download MIBs:
http://www.mibdepot.com/index.shtml
http://www.oidview.com/mibs/detail.html
http://www.snmplink.org/snmpresource/mib/#7
hopefully you'll find what you need
