clear counters command
fb_webuser
Level 11
Level 11
my cisco router 1841 is not taking clear counters commnad
Posted by WebUser Sandeep Deshwal from Cisco Support Community App
Vinod Arya
If you're checking counters via SNMP polling after using the command clear counters, thay may not work.
No commands except reboot resets the snmp counters. That commands is just for CLI commands.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Joe_george
Level 2
Level 2
Which IOS version? Do you have privledge to do that?
Does other similar platform has the same issue? It is an issue for other users on same device as well?
Vinod Arya
-Thanks
fb_webuser
Level 11
Level 11
"flash:c1841-advsecurityk9-mz.124-15.T10.bin"
fb_webuser
Level 11
Level 11
