CM vs. RME inventory
jwylie
CM= v. 4.0.2
RME= v. 4.0.2
The CM discovery is finding about 155 devices, however the RME inventory only has 139 devices.
I’ve read through the manuals and searched all over and can’t figure out why all the devices in the CM are not moving to the RME inventory. They all seem to be Cisco 6500 series switches as well.
It is my understanding that the RME inventory comes from the CM discovery.
Thanks in advance
nhabib
Level 9
Level 9
Check and see if you have unreachable devices in CM
Those will not be sent to RME
I already cleared out the unreachables. All these missing devices are reachable. I can even manage them in device center. They're just not showing up in RME Inventory. If I try to manually add them through the common services > device management it won't allow me to since there are already devices in CM with those IP's.
Some more info that may have happened to someone else.
I had previously removed all devices from RME to repopulate it. Everything had repopulated correctly besides these above mentioned switches. We recently installed a switch identical to these that are not showing up and it came over to the RME inventory without a hitch.
So it seems since I previously removed them that they're not coming back until I obviously do something to allow them to.
