CMTS Commands
mj8mj4
Hello
whats the different between ( clear cable modem(mac) reset   and    clear cable modem (mac) delete) ?
jramosg85
Hello.
When you use:
clear cable modem {mac/ip} reset = CMTS send instruction to CM that restart ()
clear cable modem {mac/ip} delete = delete cablemodem data (TXpwr, RXpwr, PHY, Counters, etc) then to no exist in the database of CMTS this mac, doesn´t send DOCSIS headers (similar to hello message) to Cable Modem and not receiving them the modem will restart.
http://www.cisco.com/c/en/us/td/docs/cable/cmts/cmd_ref/b_cmts_cable_cmd_ref/b_cmts_cable_cmd_ref_chapter_01010.html
Regards.
