CNA Configuration Archive - devices missing
Pootytang
Greetings,
I'm using Cisco Network Assistant v6.3(4) and when I try to perform a configuration archive on all my devices, only a few are listed in the drop-down. All my devices are similar Catalyst switches so I would expect them all to be available for archive. Even two of the same models aren't consistent (one is listed, one is not). Is this a known issue?
 - Difficult to tell , check credentials on those switches and check if that matches the CNA setup. You may want to check the logs on the switch when backups are tried and also CNA activity logs. CNA is old and no longer supported , you may want to consider using Cisco Prime.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
8 Replies 8
Mark Elsen
           - Note that modern switches are no longer supported  in CNA.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thanks M,
although doesn't explain why only one of two 2960's would be available for backup.
Thanks again for the reply.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thanks M.,
The log makes no mention of the switches that fail to show up in the list. The switch logs don't offer any clues either.
I'll look into Cisco Prime. No sense in beating a dead horse!
Thanks again
keep in mind the CNA is free...and Cisco Prime is VERY expensive...
All,
I found that re-discovering the community through the core switch was the main issue. I don't recall how I originally created the community but discovering via the core must not have been it. It also seems that CNA device discovery doesn't like Nexus. Seems they appear possibly through CDP but are not available when using Configuration Archive.
Georg,
the big $$$ are a no go! Thanks for the heads up!
Thanks to all who replied!
are the non-listed switches in the same network as the listed switches ? Backup config problems in CNA often are related to FTP/TFTP access. Can you manually access the non-listed switches though FTO and/or TFTP from the PC CNA is installed on ?
Thanks Paul,
Switches are all in the same network. I can TFTP the backup from the command line successfully. Will likely go M's route and investigate Cisco Prime.
