Hello
To give correct protocol labels in nfc-config.xml I need to identify witch port numbers (UDP and TCP) the collector is receiving in flows from routers.
From what I saw this must be done before aggregations because all unspecified port will appear as UDP-Other or TCP-Other.
My question is: Were can I view the content of received flow (RAW) before aggregation.
Thanks for you patience.
Nuno
