Could not open boot directory: flash:/
sugar2ferret
hi, after did a few tests with "vpn easy server"... my 871 cisco router didnt boot anymore... I think i need to
replace the image file.... in your experience why do you think it is broked now? I just signed on in the affected
router before it breaks with the cisco vpn client and everithing worked fine... then i tried to use the client from
other machine and then it didnt respond no more... do you think that failure was caused by mutiple logins from vpn client?
this is the error message im getting when booting from console port:
System Bootstrap, Version 12.3(8r)YI, RELEASE SOFTWARE)YI, RELEASE SOFTWARE
Technical Support: http://www.cisco.com/techsupportcisco.com/techsupport
Copyright (c) 2005 by cisco Systems, Inc.y cisco Systems, Inc.
C870 series (Board ID: 3-148) platform with 131072 Kbytes of main memoryKbytes o
flashfs[0]: unable to allocate available block.
flash: file system initialization failed
Unable to open boot file
rommon 1 >
I also got this print when typed the SET command:
rommon 1 > set <enter>
PS1=rommon ! >
TFTP_TIMEOUT=800000
FE_SPEED_MODE=4
TFTP_RETRY_COUNT=20
ROM_PERSISTENT_UTC=11404
RET_2_RTS=
BSI=0
RET_2_RCALTS=
RANDOM_NUM=328844401
CRASHINFO=flash:crashinfo_20060220-144320
what should i do?
ALDO
sugar2ferret
well.. i fixed it
thanks anyway
I installed the SDM, and i did configure it and the wholething... just i have a problem... once i restart the cisco router... it ask me this question: "Would you like to enter the initial configuration dialog? [yes/no]:"
And each time i restart it i have to configure it at all... is there any way to save the config the boot paramethers or some like that?
(note: of course i saved the config and i did the copy running conf to start up conf..)
For details i will include here the whole console message
Copyright (c) 2005 by cisco Systems, Inc.o find computer address to
Testing lower main memory - data equals addressN:
Router>show versionistratively downate
Cisco
Testing lower main memory - checkerboardURITYK9-M), Version 12.3(8)YI2, RE2, cha
Testing lower main memory - inverse checkerboard1(config-if)#no ip addres
LEASE SOFTWARE (fc1)ad
Clearing lower 16K memory for cache initialization.3(10.3)T29: %LINK-5-CHANGED: Interface FastEthern
Clearing bssSupport: htt
Initializing FlashechsupportEPROT
Fi
Reading monitor variables f
ROUTE
et0, changed state to downssK9-M), Ver
2,
Booting flash:/c870-advsecurityk9-mz.123-8.YI2.binter uptime is 1 minuteerface FastEthernico1(con
Sy
Self decompressing the image : #################################################ile is "flash:c870-advsecurityk9-mz.123-8.YI2.bin"00:00:46.599: %LINEPROTO-5-UPD
############## [OK]n Interface Fa
Th
Restricted Rights Legendes and is subject to UnitedO-5-UPDOWN:
Use, duplication, or disclosure by the Government isght
States and local country laws governing import,
subject to restrictions as set forth in suin
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.3(8)YI2, REws, return this product immediately.0.319: %SNMP-5-COLDSTART: SNMP agent on host
LEASE SOFTWARE (fc1)eb
A summary of U.
Synched to technology version 12.3(10.3)T2cts may be found at:g a cold start16148 bl
Technical Support: »www.cisco.com/techsupportn't
Changing crypto engine : Onboard: 0 state change to: INIT00) with 118784K/12288K bytes of memostems, Inc.s
ROUTERNAME
A summary of U.S. laws governing Cisco cryptographic products may be found at:
»www.cisco.com/wwl/export/crypto/···qrg.html
export@cisco.com.
Cisco 871 (MPC8272) processor (revision 0x100) with 118784K/12288K bytes of memo
ry.
Processor board ID FHK094812MQ
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
128K bytes of non-volatile configuration memory.
28672K bytes of processor board System flash (Intel Strataflash)
--- System Configuration Dialog ---
also i tried doing this:
copy running-config startup-config
also
copy system:running-config nvram:startup-config
and each time i turnoff and turn on the router it boot up with a blank configuration and ask for the "Would you like to enter the initial configuration dialog? [yes/no]:" each time... is frustrating...
hi
once you are up and running try keying in this command under the global mode.
config-register 0x2102
once you configure up in your router check up the same using show version command and find out in the last line whether its been replicated in your config properly.once its there in ur config do a reload and find out whether you still face the same issue..
This will for sure stop those startup dialog and help u out to get rid of your frusturation :-)
regds
thanks a lot!
you really saved my whole week!
thanks
