Collecting device configuration
bethamprashanth
Hi All,
I'm using cisco LMS 4.0, I've discovered the device and next plan is to collect the device configuration.
I would like to know,  How I can collect the configuration for single device.
What configuration changes required on my LMS & Cisco device.
Thanking You,
Prashanth
Joe Clarke
LMS will need either a read-write SNMP credential (e.g. read-write community string) or enable level CLI access via either SSH or telnet to get the configuration.  The credentials are configured in DCR under Inventory > Device Administration > Add / Import / Manage Devices.
Once you have the proper credentials configured, go to Configuration > Configuration Archive > Synchronization to collect the config for one device.
