Collecting Traffic Statistics in cisco PI
kjabhishek
I am trying to configure template for collecting traffic statistics through PI.
As per the steps in the Cisco PI document, I tried configuring the new Template, but I am not able to edit the "Form View", not able to fill any row in the "Form View" such as Flow Export Name, IP address, interface etc..
But I am able to save as a new template and publish it.
Please suggest the correct procedure and what might be the possible reason for not able to edit the Form View
Please help
kjabhishek
Please Help!
Could you share which device you want to get traffic statistics??
I want to configure on the below list of devices.
Cisco 3850 switches
Cisco Wireless LAN Controller
Cisco 3845 Routers
Cisco 4500X Switch
Cisco ISE
Go to Deployment->configuration task.
Using "Medianet - PerfMon" or "Collecting Traffic Statistics" to deployment configuration to SWs.
Please note that this procedure will change configuration of SWs.
So maybe the template command will be not correct with some devices (depend on the model).
So you need to "show run" on SWs to check the configuration are apllied or not.
If you cannot you template, you should change configuration on SWs manually.
Best Regards
