common gateway for multiple Vlan's Nexus 5596
raghavendra
Hi ,
how to create common gateway for multiple vlan's in nexus 5596 ?
I have created 3 vlans and would like to have common gateway for all 3 vlans, this requirement is to configure openstack environment.
here is the vlan settings in the nexus 5596
interface Vlan310
  description OPENSTACK-MANAGEMENT
  no shutdown
  ip address 172.29.236.1/22
  hsrp 236
    preempt
    timers msec 250 msec 750
    ip 172.29.236.3
  ip dhcp relay address 10.120.200.6
interface Vlan320
  description OPENSTACK Tunnel (VXLAN) Network
  no shutdown
  ip address 172.29.244.1/22
  hsrp 244
    name OPENSTACK-STORAGE
    preempt
    ip 172.29.244.3
interface Vlan330
  description OPENSTACK STORAGE NETWORK
  no shutdown
  ip address 172.29.240.1/22
  hsrp 240
    name OPENSTACK-TUNNEL
    preempt
    ip 172.29.240.3
Basically i want a common gateway for all 3 vlan's,  on server side with virtual nic
auto lo
iface lo inet loopback
auto enp1s0
iface enp1s0 inet static
address 172.29.236.220
netmask 255.255.252.0
gateway 172.29.236.3
auto enp1s0.320 .       <------- virtual  nic
iface enp1s0.320 inet static
address 172.29.240.220
auto enp1s0.330       <---- virtual nic
iface enp1s0.330 inet static
any help is much appreciated.
Raghavendra
balaji.bandi
As per your post -
1. In Nexus all the VLAN configured with SVI - so they already have communication between VLANs
2. why are you looking to configured 3 IP address on Linux Server, is this single interface or 3 interfaces? ( i know you mentioned virtual nic, is this virtunal nic binded to multiple physical nic in related to this server) - not whlole Esxi.
3. what is the use case of 3 IP addresses on Server?
BB
3 IPs are being configured for Openstack environment for compute node.
Basically we are creating bond interface with 2 Nic card for each Vlan creating virtual Nic.
3 IPs(subnet) will be used for management, storage and prod network
please let me know if any other information required.
