Common Problems in SG-model switches and workaround.
jai.s401
What are the common problem in SG series, and what is the alternative if budget is not an issue.
I am facing issues in SG 350 models like
Freezing of switch,
sometimes not able to telnet, ssh, or console into the device and not able  to get a connection from the port but the existing connections are still working. (we are having 4 nos. of SG-350 and 1 SG 550 as a core switch.)
Not able to view the CPU utilization as in Standard cisco switches like 3750 " Show process CPU history" which will fetch last 3 days of utilization.
balaji.bandi
Cat 1000 switches are good stable or cat 9200 if you have more budget.
https://www.cisco.com/c/en/us/products/switches/campus-lan-switches-access/index.html
BB
