Gateway for VLAN
jai.s401
1. If I create different VLANs for different Departments in a switch, should I create INTERFACE VLAN  for every VLAN created or can I simply Route that segment of IPs to a Core switch for Internet.
2.If I enable IP routing in a switch, can I write Block specific VLANs from communicating (Lets say I create VLAN1, 2,3,4,5 I want to prevent vlan 2 & vlan3 from communicating and allow all other inter_vlan communication)
balaji.bandi
You need to have respected SVI Layer 3 interface each VLAN and it should be routing aware to reach each other.
to reach the internet if the IP is not public routable address, then you need NAT
you can use ACL or VLAN ACL to achieve this.
BB
